stealth ram zz4
Old Sep 1, 2008 | 05:51 PM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
Engine: 350 zz4, 305 tbi :(
stealth ram zz4
I have a zz4 and i want to put a stealth ram on it so which size injectors should i go with?
Old Sep 1, 2008 | 06:05 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: stealth ram zz4
i have a zz4 wit ha stealth ram, i run 24#'s, runs very well
Old Sep 1, 2008 | 10:11 PM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
Re: stealth ram zz4
ive heard 24's are low do you have headers? and what is ur afpr set at? does it perform well? about how many hp?
Old Sep 2, 2008 | 07:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: stealth ram zz4
A ZZ4 engine with a Stealthram should make power up to about 5500 rpms. 24lbs injectors will work just fine. The AFPR should be around 46-48 PSI. You might need a custom chip to take advantage of the larger injectors so you'll not rich at idle.
Old Sep 2, 2008 | 10:51 PM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
Re: stealth ram zz4
do you prefer slp runners and ported plenum 58mm tb over stealth ram
Old Sep 4, 2008 | 10:12 PM
NEWMAN1786's Avatar
Car: 91 z28, 92 rs
Re: stealth ram zz4
any more input from anyone?
Old Sep 4, 2008 | 10:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: stealth ram zz4
stealth ram is better than out the box TPI setups on most motors
ZZ4 will like the stealth ram. It will be alittle better running motor than a HSR L98 like i had which i was able to make 254whp running very lean and ran 12.9's at 103.8 mph in the winter, 13.2-13.4 at 99-101 in the summer depending on conditions. stock TPI on same setup went 13.6 at 97 in the winter, so the gain was big
ZZ4 HSR is a nice combo for around 275whp well tuned with great exhaust system. should use 24 lb injectors. needs tuned to run best if using 90-92 speed density stuff.
MAF you can get away with running stock tuning with fuel pressure/timing mods but alot of power will be had with tune
Old Sep 6, 2008 | 07:35 PM
Kevin91Z's Avatar
Re: stealth ram zz4
I've never used a Stealth Ram, and I havent had a chance to put one on my engine to dyno it. The SLP runners were worth a lot more over the large tube runners, though, due to their shorter length.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
L98GTA87
Oct 19, 2015 10:43 PM
mfp189
Sep 27, 2015 09:25 AM
R3500
Sep 8, 2015 10:12 PM
