MAF question
Old Sep 6, 2008 | 10:22 AM
jstringer50's Avatar
Car: 1989 Camaro
Engine: building a 350
Transmission: TH350
Axle/Gears: soon to be 4.10 non posi
MAF question
Hey,
another question-I have an intermittent CEL on my 1989 2.8, and I pulled a code 33 when I checked it out. I checked the connector at the MAF, and everything seemed normal-close to B+ voltage at the wire coming from the MAF relay, close to 5v at the PCM wire, and a good ground. while these values seem good to me, i am having trouble getting specs and good information for this engine/car (chiltons and haynes dont really give much info other than wiring diagrams). are these numbers good, or do I have a problem? is it simply time for a new MAF, or is there more troubleshooting I should be doing? thanks
Old Sep 6, 2008 | 01:13 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: MAF question
Originally Posted by jstringer50
Hey,
What I have on the code 33 is the voltage from the MAF is higher than it should be for a given throttle. Voltage to the ECM with the wire connected to the MAF should be close to .5v at idle and 4.7v at WOT.
Remember the ECM is comparing things to see if something doesn't agree. It knows if the throttle is showing close to idle there can't be a ton of air going across the MAF.
If the values of the TPS and MAF are in valid ranges, it can't be sure "who" isn't telling the truth; but it knows someone is lying. Example: TPS showing WOT and MAF indicates a trickle of air (code 34).
Verify the TPS wiring and that it is outputting a smooth voltage change when moved and is calibrated.
chazman
Aug 28, 2018 03:25 PM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
