Rebuilding heads....question
Old Sep 6, 2008 | 03:40 PM
Joelfke's Avatar
Car: 1991 Camaro RS Conv
Engine: 305 V8
Ive got a 91 camaro RS with a 305 V8. I need to rebuild the heads on it (which sounds like loads of fun)
question is this: would i do more harm then good by replacing the lifters while ive got the heads and intake off anyway? would putting in a new set of lifters mess up the old cam?
Old Sep 6, 2008 | 03:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Rebuilding heads....question
You could replace them if you wanted to spend the money, but you don't need to.
Why do you need to rebuild the heads?
Old Sep 6, 2008 | 03:48 PM
Joelfke's Avatar
Engine: 305 V8
start up the car...smoke out the back for only a few seconds and when im at a light it will smoke for a second or two off the light.....everyone ive talked to says that its because the valves are bad
Old Sep 6, 2008 | 04:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not your valves, just the valve seals. You can replace them without taking the heads and intake off.
Old Sep 6, 2008 | 05:38 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
its been done many times with good results . be sure to clean sludge from drain holes at front and rear of cylinder heads . they allow oil to drain back to crankcase . do alot of searchs , they will tell you how . good luck .
Old Sep 7, 2008 | 04:20 PM
Joelfke's Avatar
Engine: 305 V8
id feel better just rebuilding the heads..then i can put on new gaskets and springs and all that stuff
still dont know if it would hurt the old cam if i put on new lifters tho...
Old Sep 7, 2008 | 04:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You don't need to take the heads off to change the springs, either.
You won't hurt a roller cam putting new lifters on, but there's no reason to put new lifters on.
Old Sep 7, 2008 | 07:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Instead of replacing the good parts, why not just replace the bad ones? Save some cash man.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
