Noob Question
Old Sep 9, 2008 | 02:41 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Noob Question
This is a silly question, but I'ver never changed the oil on my car. I'm low on oil from what the guage says, and the car is heating up very quickly so that has to be the problem. I don't have the tools to go under the car so could I just pour some oil done the tube till I get all my oils changed a month or 2 from now (long story )
If so, what oil should I get? I don't need anything real good just something basic to tie me over, the car has 92,000 miles and the oil guage read 30 out of 60.
Old Sep 9, 2008 | 03:06 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Noob Question
The gauge your talking about is the oil pressure. You need to go under the hood and check the oil dipstick and see where your oil is at.
Old Sep 9, 2008 | 03:48 PM
Mason85V8's Avatar
Re: Noob Question
dude.. learn how to change your oil.. its pretty simple
Old Sep 9, 2008 | 04:01 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Re: Noob Question
I told you I was a noob,
Well I checked my oil when it was running..like the stick itself said and I'm in the middle between cold and hot, and it should be in the hot area since the car was hot. I have 2 qts of this stuff that I'm gonna put it to tie me over, I'm not actually changing the oil just putting some in to tie me over for a month or 2. (very light driving) maybe 12mi a day only 5 days a week.
How much should I put it?
Old Sep 9, 2008 | 04:11 PM
buell's Avatar
Car: 87 camaro iroc
Engine: 5.7L
Re: Noob Question
btw if you get on your aim itll b alot quicker to type back n forth
umm do u want to change it or do u want to add fluid?
change:
go underneath the car and take off the drain plug. This is located at the back of the oil pan. After oil has drained most of the way out then take off the filter and put new one on after putting oil around the seal then tighten by hand so that u can get the filter back off. Next put the drain plug back in and then look at the engine form the top. On the right valve cover there is a black cap towards the back of the engine twist this off and put your oil in there (careful how much, can explain this in more detail if you want) after waiting a few mins check ur oil level.
add fluid:
take off previously mentioned cap and add in oil. Btw i'm currently using penzoil high-mileage oil that i got on sale at jiffy lube and i havent noticed any problems from it yet. Though a month after i changed my oil i had to add another complete quart, thought i havent seen any leaks (father said for the first few changes it will burn some oil.....) Ohh i was told to def not switch to the synthetic b/c anything over 50k (i think) miles any it will ruin your seals, Pretty much synthetic in high miles vechile= no.
Lastly sorry if this post made it seem like you are an idiot i just didnt know wat you meant by pouring oil into the tube.....
Old Sep 9, 2008 | 04:18 PM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Re: Noob Question
Hold up a minute here.
Do you want oil or trans fluid
The reason I ask is you check oil cold not hot
you check tranny fluid hot.
Also the oil dip stick does not say hot/ cold on it the trans dip stick does.
you do not add oil thru the dip stick tube you add it thru the hole in the valve cover were the oil cap (probalby on the drivers side valve cover) is it will be marked and should say what oil viscosity to use.
With more then 93000 on my car I only use mobil 1 full synthetic. other then a leaky valve cover(my fault it leaks and don't want to replace bc motor swap this winter) I have no leaks
Old Sep 9, 2008 | 04:42 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Re: Noob Question
I didn't put any in yet,
So your saying that dipstick way in the back is the oil? But to fill it there is something up front? Ahhhh let me look around some more thanks for the help so far.
Old Sep 9, 2008 | 04:51 PM
buell's Avatar
Car: 87 camaro iroc
Engine: 5.7L
Re: Noob Question
I didnt even think of that..... yeah the oil dipstick says something about add one quart towards the bottom of it. Its the dipstick farthest away from the back of the engine bay.
Old Sep 9, 2008 | 05:05 PM
vette9190's Avatar
Re: Noob Question
Oil Dipstick is Black handle shaped like a T Pass side middle of valve cover
Trans dip stick Red or Grey handle shped like ring you can put a finger thru Pass side back of engine by fire wall.
Oil cap( were to add oil) Driverside valve cover toward rear
I'll look for a pic to show
Old Sep 9, 2008 | 05:10 PM
vette9190's Avatar
Re: Noob Question
Here are Pics
Old Sep 9, 2008 | 05:18 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like the power steering dipstick.
Old Sep 9, 2008 | 05:20 PM
buell's Avatar
Car: 87 camaro iroc
Engine: 5.7L
Re: Noob Question
That's weird because both of my handles are shaped like the trans one that u described and they're also gray. ehh ohh well mines an 87 iroc 5.7 so i guess it changed over the yrs..... n i can prolly get a pic up by the end of the night if thats wat needs to happen
Old Sep 9, 2008 | 05:45 PM
vette9190's Avatar
Re: Noob Question
Yeah his being a 92 I think will be closer to My 91 then ur 87 Buell but I thnk more pics would def help.
five7kid I didn't even think about that he could have been looking at that too but he said this in a later post
So i don't think he's talking about the power steering but good catch anyways
Old Sep 9, 2008 | 05:55 PM
buell's Avatar
Car: 87 camaro iroc
Engine: 5.7L
Re: Noob Question
power steering is a black case on the front of the engine by the serpentine belt. and the stick is hard and attached to the lid plus only 3ins long. i doubt that is what he was looking at..... well atleast on my car thats how it is
Old Sep 9, 2008 | 06:08 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Re: Noob Question
Thank you so much, I ALMOST made the mistake.
Learn something new everyday!
Kudos
Old Sep 9, 2008 | 07:01 PM
buell's Avatar
Car: 87 camaro iroc
Engine: 5.7L
Re: Noob Question
heres the pics i have... Sry if they're a little blurry they were taken with a camera phone:
umm let me try that agian
and also since it was mentioned earlier.... ?action=view&current=0909081902b-1.jpg&t=1220929602789
Old Sep 9, 2008 | 08:30 PM
Mason85V8's Avatar
Re: Noob Question
seriously man.. just go to the store buy a 4.4l thing of oil(plus one more) and change it its not hard and it will be worth it.. and check your oil everyday in the morning before you start the car
Old Sep 9, 2008 | 08:31 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Re: Noob Question
Thanks for the pic, I'm gonna have to look for the oil dipstick again tomorrow. I looked for a good 30min in that area and couldn't find it!!!!
I don't have a loop like you so maybe it broke off or something, I put one quart of the correct oil in the car, 1 is better than none.
I will change the oil myself, someday but right now I don't have jacks stands and the neccessary tools to do it. My dad forbids me to go under the car also.
Relative got killed that way so I don't blame his protectiveness.
Old Sep 9, 2008 | 08:35 PM
Mason85V8's Avatar
Re: Noob Question
you dont need to jack the car up.. and if your low one is good but you put to much oil and BAM! engine is toast.. I know i did that to my Cav
Old Sep 9, 2008 | 08:58 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Re: Noob Question
Why don't you start fresh and do an oil change/maybe a whole tune up? So at least you have point to start from. It is not that expensive.
Old Sep 9, 2008 | 09:01 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Re: Noob Question
How am I gonna get under the car to drain the oil without jacks lol?
I put one in, it started right up and I let it idle for awhile. Suppose I were to put to much in, why would my engine be done?
Old Sep 9, 2008 | 09:05 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Noob Question
This is a joke, right? Gotta be....
Old Sep 9, 2008 | 09:15 PM
lownslow's Avatar
Car: 1986 Sport Coupe Camaro
Engine: 305 TBI
Re: Noob Question
Why is a noob driving a Camaro?
Old Sep 9, 2008 | 09:23 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Re: Noob Question
Ok even if he is a noob, his first investment should be a decent set of jackstands and a jack, or he should not be working on his car
Old Sep 9, 2008 | 09:29 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Re: Noob Question
What does noob have anything to do with it?
Be Nice, you didn't learn overnight either.
Old Sep 9, 2008 | 09:32 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Re: Noob Question
I am not trying to put you down... we were all noobs at some point. I am just saying to work/troubleshoot any car you need the proper tools.
Old Sep 9, 2008 | 09:40 PM
buell's Avatar
Car: 87 camaro iroc
Engine: 5.7L
Re: Noob Question
Hey least hes not another *****. Give him a break everyones got to learn somehow.Yeah relative of mine went the same way to man, all bout knowing where to put the stands and how t put em. Ohh you can prolly just manage to fit under the car while its down or if u have it to drive it to the edge of something where it would make it easier to crawl under
Ohh btw my cars older so ur handles might b different, one guy said that the one you need would most likely be a black 't' handle
Old Sep 9, 2008 | 09:53 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Re: Noob Question
Im not calling the guy a *****. Im trying to help him succeed in any car he works on, not just his camaro.
Mason85V8's Avatar
Re: Noob Question
you put to much oil in and your seals blow, bearings get ****ed.. bunch of bad **** happens. I'm sure you can get under it without a jack
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Re: Noob Question
Yea I looked up a '92 camaro oil dipstick and a few sites selling them had the 'T' looking going on with them, I saw no such thing in my engine bay.
Tomorrow if I don't find it, I'll snap some pics of my engine bay and maybe you can find it lol.
Old Sep 9, 2008 | 09:55 PM
Mason85V8's Avatar
Re: Noob Question
you know if you pulled out the dipsticks you would know which one is oil..
Red = Tranny Fluid
Brown or Black = Oil
Old Sep 9, 2008 | 10:11 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Re: Noob Question
yea buddy I found my tranny fluid alright, I'll check again tomorrow morning and then after school.
Old Sep 9, 2008 | 10:55 PM
buell's Avatar
Car: 87 camaro iroc
Engine: 5.7L
Re: Noob Question
yeah add some pics and we'll help u locate it im sure (btw capture the right side of the engine and give us plenty of light to look).
Rofl i nvr knew that the cuss words on here and the evil r word... ***** all had ***** put in place of them by the website itself.
Old Sep 9, 2008 | 11:25 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Re: Noob Question
just a fyi i actually manually entered the ***** it was sarcastic, i really want to help this guy
Old Sep 10, 2008 | 08:05 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Re: Noob Question
Z2eight do yourself a favor and go to any auto parts store and pick up a repair manual. It will show you anything and everything about your car and it has step by step instructions and pics also. It might be a bigger help looking at that then constantly go back an forth on here. They look like this :
http://cgi.ebay.com/Chiltons-GM-Chev...QQcmdZViewItem
Old Sep 10, 2008 | 02:27 PM
buell's Avatar
Car: 87 camaro iroc
Engine: 5.7L
Re: Noob Question
Ohh well above you i didnt put in the '*' but it still came up that way..... though i did figure out that if you really want to put a word just do this: (worked last night...)
*******-r/ r ice r and its shows up or spaces or..... ahh my eyes i can't see anymore, I'm sorry thirdgen ill never use that evil word again. I swear on my camaros [non-exisitant] grave
Old Sep 10, 2008 | 02:35 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Re: Noob Question
these are 2 older pics, the ones i just took did not upload right
Old Sep 10, 2008 | 05:26 PM
buell's Avatar
Car: 87 camaro iroc
Engine: 5.7L
Re: Noob Question
Picture is too blurry to tell anything really.... what is the ? though? also the manual the one post mentioned is a great idea i picked up one myself at the local pep-boys / salvo and its helped me more times then i can remember... also at somewhere around $20 they are one of the best investments i have ever made
Old Sep 10, 2008 | 08:22 PM
vette9190's Avatar
Re: Noob Question
Ok see the big silver cylinder thing on the left
Just next to it on the right look in that area you should see the oil dipstick
Old Sep 10, 2008 | 08:47 PM
buell's Avatar
Car: 87 camaro iroc
Engine: 5.7L
Re: Noob Question
Umm are u talking bout the air conditioning unit? and i thought the trans was next to it and the oil was farther forward, either way mines taking out lol.Isnt that a picture of his engine bay? i was just saying if it was clearer we could point out exactly where it was for him
hey vette how do u like that hhr? no offense but i dont like the look of them or cars with that body style in particular....
reason i bring it up is i was just wandering how comfortable they r, how they handle how much storage there is, practicallity, mpg.... u know just curious but the car is all
Old Sep 10, 2008 | 09:11 PM
Nater2491's Avatar
Re: Noob Question
there are two dip sticks on the left side , it is the one closest to the front. its not hard to find.
alright i just went out and looked for you on my car. look at your motor from the front of the car. to the left there is a cylinder shaped piece of metal that is silver. its a little bigger than a pop can. go two inches or less to the right, there should be a tube there with a handle coming out of it, although it is possible you dont have a dip stick. but the tube should still be there, it will be a very small tube like the size of a straw
Old Sep 10, 2008 | 09:35 PM
  #42
rsrookie's Avatar
Car: 1992 Camaro RS t-top
Engine: 305 Jasper
Re: Noob Question
Okay noob, don't let these other cats bust your do-dads over this.This is what you do.Pop the hood and get a flashlight, whether it's sunny outside or not.Look CAREFULLY and SLOWLY, "feel" if you have to, to find your dipsticks.The oil dipstick is closer to the front of the car and the trans dipstick is closer to the firewall, er, windshield. My oil dipstick has a black T shaped handle with the words "engine oil" on it.The trans dipstick is red and has a ring shaped top.A REMINDER--check trans fluid when the engine is warm and running.Check OIL when the engine has been off for awhile, or first thing in the morning.Don't fart with the trans dipstick at this point; it dosent have Bo Diddley to do with oil pressure.Found it?Good! IF NOT take the car to a decent quick lube place (not jiffy IMO) and watch what they do.I have been changing oil since I was 13 (older bro's 55 Chevy),but I had to break down and take my RS to a Valvoline instant oil change simply because the car sits so damn low and my ramps would ^*** up my front spoiler.Lastly, get the correct Chilton's book for your car.Learn it- live it!!
Old Sep 10, 2008 | 10:04 PM
  #43
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: Noob Question
Go to an oil change place and pay the $36 bucks. Then watch what they do. It'll be a cheap oil changing lesson. This is what's wrong in America today. No vocational classes in our schools like auto shop, wood shop, mechanical drafting...
You'll figure it out. Once you're done you'll be saying two things to yourself.
1. "That was easy."
2. " What do I do with this #$@&" ?????
Old Sep 11, 2008 | 06:22 AM
  #44
rsrookie's Avatar
Engine: 305 Jasper
Re: Noob Question
TRUE DAT!!!
Old Sep 11, 2008 | 06:28 AM
  #45
vette9190's Avatar
Re: Noob Question
Buell The HHR rocks. I had the 07 and it got totaled now I have an 08
I use it for work and often hall 4 containers in the back that are 3ft long 1.5 ft wide and 1.5ft tall with the back seats up I get around 28 combined mpg with the equipment in the back weighing almost 300lbs. It works great for me bc I have 2 kids. They love it almost as much as they love my camaro. Of course The deal i have on it you can't touch car, ins, and full maint for 180 a mo(sorry only for me bc I'm special) but I highly recomend them. Oh and by the way 40mph front impact into a car that turned in front of me and I walked away. Any car that you can do that in has my vote.
Nater That is what I was trying to say I think you may have said it better though.
go to a quick lube and watch
On a side note I just realized you said when you checked it was low but we all realize you actually checked the tranny fluid so I think you need 1/2 a quart of tranny fluid too.
quote z2eight
Old Sep 11, 2008 | 09:51 PM
  #46
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Re: Noob Question
Ok, well before school I'm gonna find this SOB. I'll try uploading the pics again because I see no T shaped handle with ENGINE OIL printed on it.
Old Sep 11, 2008 | 10:07 PM
  #47
Kevin84Z28's Avatar
Re: Noob Question
Have one of the girls at your school show you. Just kidding, really. You're not trying hard enough.
Old Sep 11, 2008 | 10:52 PM
  #48
Mason85V8's Avatar
Re: Noob Question
just pull the dipsticks out till you find the one covered in oil.. wow man seriously not trying to be a **** but how are you gonna swap to a 350 if you dont know how to change your oil..
Old Sep 11, 2008 | 11:02 PM
  #49
Kevin84Z28's Avatar
Re: Noob Question
OK, this should just about be the last post on this thread except for the one you send stating, "Ok got it, thanks."
Old Sep 11, 2008 | 11:11 PM
  #50
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
Re: Noob Question
My girlfriend can change her oil and filter, and now brakes too
