cam selection...help
Old Sep 17, 2008 | 08:35 PM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
Had some probleme this season with rocker and tuning my car. After some check up, cam lobe are wiped(3-4).....cam have about 2-3k km so I failed my cam brake-in. Anyway i can live with that.
So I need a new cam, while there im going mec roller
engine spec
350 bored 0.040 about 9.5 to 1 comp
perf rpm 64cc head
perf rpm air gap intake
650 holley DP
lt 1"5/8 with dual 2"1/2
old cam was xe 274....was able to get some low/mid 12sec run with the wiped cam
car setup....3500stall, 700r4 full man shift kit, 4.10 gear with 28" slick....race weight about 3500-3600pounds
ill try to raise comp ratio in the 10.5-11 range with forged flat top and i will run 100 to 150 shot....might go higher on the juice
crane recommend me the powermax 118551, just want some opinion on this and maybe other cam option
thanks
Seb
Old Sep 17, 2008 | 10:30 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: cam selection...help
powermax 118551 is a hyd. roller, Not a mech. roller. If you drive the car on the street I would run the hyd. If your car is a strip only car I would run the mech. cam. This cam looks a great choice.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
