Newbie needs gasket help
Old Sep 19, 2008 | 05:07 PM
mgray1982's Avatar
I have to replace my t-stat, and I got the fabric gasket, but do I need to add some silicone or RTV liquid gasket stuff??
I've always just used the fabirc material gasket, but I see/hear people using the liquid paste stuff.
What's best and why?
Old Sep 19, 2008 | 08:30 PM
jpeden31's Avatar
Car: 1984 z-28
Engine: 305H.O. L69
Axle/Gears: 3.73 G80 GT4
Re: Newbie needs gasket help
personal preference, if it wont seal with just a gasket then there might be warping, i use just a little myself mainly to help me sleep better at night but its not necessary
Old Sep 19, 2008 | 09:08 PM
mgray1982's Avatar
Ok cool, but what is the proper liquid stuff to use? I hear about different types like silicone, rtv, high temp etc. I also hear some types is bad for some uses (i think it was silicone you gotta be carefull with?). What should I use for the t-stat?
Old Sep 19, 2008 | 09:21 PM
jpeden31's Avatar
Car: 1984 z-28
Engine: 305H.O. L69
i've used most hardening and non hardening and rtv but no silicone yet and as long as it says its okay being in the antifreeze environment its fine, can't think of any that you shouldnt use really
Old Sep 20, 2008 | 11:02 PM
vette gator's Avatar
Car: 85 Z28
I've always used regular black RTV and worked a thin coating onto both sides of the gasket. I do the same thing with valve cover gaskets and no leaks in anything so far.
Old Sep 20, 2008 | 11:05 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
rtv black is the safe all purpose gasket maker to use, never use the blueish clear silicone on aluminum its acidic and will eat the aluminum. just stick with RTV BLACK.
http://www.permatex.com/documents/Ga...erSelector.pdf
Last edited by igotta355z28; Sep 20, 2008 at 11:07 PM. Reason: Automerged Doublepost
Old Sep 20, 2008 | 11:51 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Go with the black, I use that stuff for everything.
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
rubblerubble
Mar 13, 2016 06:57 PM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
