No ECU codes, timing retarded, rich fuel mixture
Old Sep 24, 2008 | 07:46 AM
GunGreyForm's Avatar
All,
I am continuing to try to get my 1990 305 TPI tuned and able to pass Virginia emissions. I am having the following issues:
I get no ALDL data at all (not even a code 12) when I jump the ALDL
My timing is retarded by about 10 degrees (at 12 oclock); jumps around 2 to 3 degrees at 750 rpm idle speed
My SES light NEVER comes on--not even at start up
I can easily smell that my car is running very rich
I replaced the 02 sensor with a GM sensor, replaced the plugs, wires, distributor cap & rotor. Used GM top end cleaner, etc.
The car idles fine and seems to perform *okay* for a 305. It will still not pass emissions though and the lack of ALDL data baffles me--as does the timing being so off. I can adjust the timing but suspect all of this might be related and that might not be the real problem.
Does anyone have any wisdom on what to check to see why I am having these issues?
Old Sep 25, 2008 | 09:09 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: No ECU codes, timing retarded, rich fuel mixture
Originally Posted by GunGreyForm
...I get no ALDL data at all (not even a code 12) when I jump the ALDL...
Change the bulb? It was probably removed by the P/O that didn't want to fix the car if it still "ran".
Azrael91966669
25
Jun 20, 2017 04:04 AM
italiano67
Dec 11, 2016 09:21 AM
Caspar
Jun 19, 2016 11:19 PM
djmarch
Aug 9, 2015 05:27 PM
