Roller Block Cam Retaining Plate Bolts....
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I need to know the thread size of the two bolts that hold the cam retaining plate on a factory roller block. One is stripped and will need to be drilled out and helicoiled
Transmission: 4L80E/4L80E
I know the plate was discussed at length a couple of years ago, but I don't recall a discussion about the bolts. Did you
Easy enough to take the bolt to the hardware store and match it up.
?Easy enough to take the bolt to the hardware store and match it up.
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
