car boggs when gas pedal is pushed from a stop
Old Sep 27, 2008 | 08:18 PM
bcfipp's Avatar
Car bogs when accelerating from a stop. any ideas. Another question. If oxygen sensors are bad will there be a fuel type or raw smell. car is a 1991 chevy camaro tpi z28 305
Old Sep 27, 2008 | 08:26 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
Re: car boggs when gas pedal is pushed from a stop
if your 02 sensor is bad you will be running rich which sounds like your problem is your check engine light on?
Old Sep 27, 2008 | 08:33 PM
bcfipp's Avatar
The light comes on. Then when the car is off, after i turn it on it will come back on by the end of the day.
Old Sep 27, 2008 | 08:37 PM
Engine: L69 H.O
do you know how to flash your trouble codes
Old Sep 27, 2008 | 09:14 PM
bcfipp's Avatar
no i don't i heard use a paper clip
Old Sep 27, 2008 | 09:24 PM
Engine: L69 H.O
https://www.thirdgen.org/service-eng...ht-error-codes try that and let me know what code you come out with
Old Sep 27, 2008 | 09:34 PM
bcfipp's Avatar
is the connector under the dash or in the engine compartment
Old Sep 27, 2008 | 09:51 PM
Engine: L69 H.O
should be right under the drivers side of the dash on the right hand side may have a plastic cover over it should pop off no problem just remember not to start the car with the paper clip in and to remove it before turning the key off
Old Sep 27, 2008 | 09:59 PM
bcfipp's Avatar
thanks for the help I will let u know what i find
Old Sep 27, 2008 | 10:29 PM
Engine: L69 H.O
alright
Old Sep 28, 2008 | 08:18 AM
bcfipp's Avatar
the code is 45 oxygen sensor rich
Old Sep 28, 2008 | 10:22 AM
Engine: L69 H.O
yep running rich would make it bog just replace the o2 sensor its on the drivers side exhaust manifold that should help with it bogging off the start. let me know if you need anymore help.
Old Sep 28, 2008 | 01:57 PM
bcfipp's Avatar
awesome I will let you know. Thanks again for the help
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Sep 1, 2015 03:51 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
