Need Help Choosing cam
Old Sep 28, 2008 | 10:23 PM
Redlinerevver's Avatar
Car: 84
Engine: 360 210 alumium heads
Transmission: th350 3600 stall w/shift kit
Axle/Gears: floater Ford 9" 4.56 full Lw spool
HI, I need help picking a cam for my drag car.
Heres my engine combo
350 bored .060 over
will be running 11.7 compressiong ratio
Procomp 210cc aluminum heads
have head man headers to 3in to purple hornies.
4:10 gears
th350 trans
have 3200-36000 conveter
1.6 Ratio rr
I want to get a macanical flat tappet cam thats wild. what as much hp/torqe possible with under .600 lift Hoping for around 530Hp.. or more
here are ones im looking at.
Lunati 40135 244-254d 532/552L
Lunati 40156 244d 530/543L
Old Sep 28, 2008 | 11:00 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: Need Help Choosing cam
If you'll be using a single plane manifold like a Vic JR or....
Use Isky cam #201549 Install on a 100 to 102 intake C/L.
Lock the spark timing out 34 to 36deg full time. (no mechanical advance)
Don't forget to hang on.
Your cr is a bit high for pump gas. I would not run it on anything less than 100 octane gas.
you can look up the cam specs yourself.
www.iskycams.com
Old Sep 29, 2008 | 09:01 PM
Car: 84
That looks like a good cam.. Is that what you run? I have a pro products hurrican intake with a 750 carb Ill pry move up to a 800 or 850cfm..
I am Thing of going to a weiand stealth air strike..
Thanks for the help F-Bird'88
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
