custom cams who made it?
Old Sep 30, 2008 | 08:31 PM
91redz28's Avatar
Car: 91 CAMARO Z28,91 GTA
Engine: 305 TPI modified, 350 tpi
Transmission: 700R4 modified
Axle/Gears: 2.73 (yuck), 3.23 posi
what does everyone think about lloyd elliott ?
Old Sep 30, 2008 | 08:39 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: custom cams who made it?
For LT1 motors he's pretty good and offers great setups. AI (advanced induction) is the other big LT1 player. They offer great stuff too.
Either setup is fine for LT1's, they both offer great packages to suit your hp needs from bolt ons/stock heads to fully ported heads and all out max power on stock shortblocks. After that they can play with aftermarket LT1 heads and bigger cams to see more power.
Lloyds cams used to be ground by BRE, bret bauer racing engines. Did a good job. Never seen a poor combo by him. Infact i'm running one of his cams in my 383 and its doing pretty good so far. Hit my goals at the time. I told him what i wanted, what i had in mind, and he gave me something abit different than what i expected but the car did what i said i wanted.
Lloyd Elliot now uses grinds from bullet cams as they are offering cheaper grinds than what bret bauer racing could offer... so it was a business decision. I havent seen any recent LT1 setups using the new grinds from bullet but i have heard bullet is pretty good cam grinder. you cant go wrong tho
Old Sep 30, 2008 | 09:20 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I'm running a Bullet cam, and I think it's great. I had a trick flow hydraulic roller 246/254 .558/.558 and ran 10.4's, and the switch to this solid roller 264/271 .626/.626 made it run 10.0's
Old Sep 30, 2008 | 09:51 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Cam Motion is the only name in custom cams in my book
Old Oct 1, 2008 | 05:32 PM
91redz28's Avatar
yea getting a custom cam ground by lloyd for my l98. it should be bad *** for my setup
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kah992
Aug 19, 2015 02:55 PM
