1988 camaro check engine light
Old Oct 3, 2008 | 10:36 AM
acalwell's Avatar
i was talking to morley about my 1988 camaro 2.8 that was reading code 32 for the egr solenoid and lost my user name and password so had to join again. ok i replaced the egr vacuum solenoid and the check engine light didnt come on entill yesterday again and its reading code 32 again. so should i just replace the egr solenoid? thanks april
Old Oct 3, 2008 | 11:01 AM
acalwell's Avatar
Re: 1988 camaro check engine light
i am sorry i mean should i buy the egr valve and see if thats it since it wasnt the egr vaccuum solenoid. thanks april
Old Oct 3, 2008 | 03:34 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
you should try posting this in the tech general engine board you will get better results
Old Oct 3, 2008 | 05:24 PM
acalwell's Avatar
ok thanks i will. april
Old Oct 3, 2008 | 10:35 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
I'm not sure if the 2.8L ECM works the same as the V8s, but I believe the V8 ECMs will command the EGR and expect the MAP to drop. If it doesn't drop it'll trip a code. You might need to remove the intake and clean the exhaust crossover. Hope this helps.
Old Oct 4, 2008 | 10:57 AM
acalwell's Avatar
i have cleaned the intake and excaust crossover but no luck. thanks april
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
