Fuel pump options
Old Oct 3, 2008 | 04:59 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Fuel pump options
My fuel pump died on my 92' camaro. I have a mallory 4309 FPR for my holley 650. If i replaced it with another tbi fuel pump would it go out again since im running an fpr? Or should i just get a mechanical pump? If i should go with a mechanical pump which one should i buy and do i replace it with the old fuel pump or does it go on the block? How should i go about placing the fuel pump because i heard you have to drop the rear end. I've also heard you can just pull out the back seat and put the pump on top of the gas tank.
Old Oct 3, 2008 | 11:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The in-tank pump is going to have to come out one way or another. Might as well do it right and drop the tank. A TPI replacement or some aftermarket like Walbro 255 would be a better choice than TBI replacement, and would serve you well with the 4309 reg.
Old Oct 5, 2008 | 09:32 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Re: Fuel pump options
I went and bought a replacement Bosch fuel pump. It has a lifetime warranty and it was only fifty bucks. So you have to drop the rear end to get the tank out or can you pull the back seats and carpet out?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
