Fuel feed, return, vapor line sizes + AN
Old Oct 5, 2008 | 05:09 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Can someone tell me what sizes the fuel feed, return, and vapor lines are on an 89 tpi car? What are the -AN equiv's and what fittings do I need to attach the lines? I have a 37 degree flare tool to flare the lines after I cut them back (I need to because of a rusted section) but I don't know what fittings I will need and what size line. Also what fittings would I need to connect the other ends to the tpi fuel rail? Would I be ok just using clamps on the vapor line?
Old Oct 5, 2008 | 05:20 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Fuel feed, return, vapor line sizes + AN
I don't know for sure, but I'd say the supply is a 3/8" and the others probably 5/16" or 1/4". AN sizing is in sixteenths of an inch, so -6 would be 3/8" and -4 would be 1/4".
Old Oct 5, 2008 | 05:21 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The numbering system for AN hose and fittings is pretty simple - its a measurement in 16ths of an inch.
EX.
-6AN = 6/16" = 3/8" hose
-8AN = 8/16" = 1/2" hose
If I remember right, the stock inlet fuel line is 3/8" (-6AN) so you'll need fittings to match that. The original parts that had threaded fittings, like fuel rails, had NPT threads not AN threads, but there are adapter fittings available to make it work. Russell makes any fittings you'll need.
Old Oct 5, 2008 | 07:37 PM
89RsPower!'s Avatar
Thanks guys! By any chance can anyone point me in the right direction as far as part numbers? I'm horrible at finding the right fittings and I've had the sales reps at summit set me up with the wrong parts before.. any help in that matter would be greatly appreciated. Also as far as the vapor line, can I simply use clamps for that hose?
Old Oct 5, 2008 | 09:47 PM
Air_Adam's Avatar
Before anyone can do that, we need to know what you need - like straight fittings, 90* fittings, etc etc.
The best way for you to do this though, now that you know what size hoses you need, is to go to a local speed shop and see what they have there, so you can actually see the parts. They will be able to tell you what will work, what you may or may not need, and show you how to assemble everything correctly.
This is one of those things, IMO, thats better seen in person than described over the internet.
If you still want our help though, we'll do what we can for you.
Old Oct 5, 2008 | 09:54 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Here is something that I started a little while ago. I am going to complete the "written" process soon. I will post some stuff in a bit for you.
In my opinion the only place to go is www.anplumbing.com. It is Earl's Plumbing fittings. They are the best price online and they have how-to videos as well.
Attached Thumbnails Fuel feed, return, vapor line sizes + AN-hardline-fittings.jpg
Old Oct 5, 2008 | 09:58 PM
dctrumpet's Avatar
The Earl's fittings you see in these pics are used if you decide to cut your hardlines and adapt to AN fittings. They are your basic compression style fitting and they will adapt to -6AN.
Attached Thumbnails Fuel feed, return, vapor line sizes + AN-104_1650.jpg   Fuel feed, return, vapor line sizes + AN-104_1714.jpg   Fuel feed, return, vapor line sizes + AN-104_1715.jpg
Old Oct 5, 2008 | 10:01 PM
dctrumpet's Avatar
These two fittings will convert your existing flexible lines to -6AN. These fittings also work if you remove your flexible line and leave the stock fittings on the hardlines shown above.
Attached Thumbnails Fuel feed, return, vapor line sizes + AN-104_1699.jpg   Fuel feed, return, vapor line sizes + AN-104_1700.jpg
Old Oct 5, 2008 | 10:03 PM
dctrumpet's Avatar
This is assuming your TPI lines are like the TBI. From what I know they are the same.
Old Oct 5, 2008 | 10:11 PM
dctrumpet's Avatar
This page from Russell's might help.
File Type: pdf
Old Oct 5, 2008 | 10:18 PM
dctrumpet's Avatar
These are the adapters for the back of a TBI in case someone asks...
They are Earl's
14mm male with o-ring to -6AN male Part# 991954
16mm male with o-ring to -6AN male Part# 991955
Old Oct 5, 2008 | 10:20 PM
dctrumpet's Avatar
Hope this helps someone!
Old Oct 5, 2008 | 10:29 PM
89RsPower!'s Avatar
Thanks for all your help, I found everything I was looking for on summit but will check the site you listed to see if prices are better before I order, Thanks guys!!!!!!!!!
Old Oct 5, 2008 | 10:31 PM
dctrumpet's Avatar
Almost guaranteed to be better prices on anplumbing.com.
What are the sizes that enter the fuel rail?
Old Oct 5, 2008 | 10:32 PM
89RsPower!'s Avatar
they are both 16mm x 1.5
Old Oct 5, 2008 | 10:33 PM
dctrumpet's Avatar
Cool!!!
Old Oct 5, 2008 | 10:35 PM
89RsPower!'s Avatar
is there a russel equivilent of this piece? I need two http://store.summitracing.com/partde...art=RUS-648060
nm just saw you listed it: 991955
Old Oct 5, 2008 | 10:38 PM
dctrumpet's Avatar
This is the Earl's equivalent as shown above:
That same fitting can also work on the power steering. I believe the power steering fittings are 16mm and 18mm
Old Oct 6, 2008 | 03:14 PM
89RsPower!'s Avatar
I was mistaken, the parts in post #8 are the ones I need to connect to the extension piece that connects to the fuel rail, the return is in fact 14mm
Old Oct 6, 2008 | 03:25 PM
89RsPower!'s Avatar
to use the tubing connectors you need a flare tool correct?
Old Oct 6, 2008 | 05:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
To use a tube nut and sleeve, you need a flare tool.
Old Oct 6, 2008 | 06:25 PM
89RsPower!'s Avatar
so if I use the compression fittings dc mentioned I don't need to flare the line ?
Old Oct 6, 2008 | 07:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you use compression fittings, you don't need to flare the line.
toronto formula
Nov 10, 2015 06:17 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
