Reseting Codes
Old Oct 6, 2008 | 08:11 PM
Redwhisper's Avatar
Car: 86 IROC-Z
Engine: 97 LT1
Reseting Codes
I am having trouble reseting the codes on my 1986 IROC. The code reader will not reset them, I pulled the fuse to the ECM still no luck, the only way I have been able to clear them is to diconnect the battary, that's a pain. Do I need a new reader? Is there an easier way to cut all the power to the ECM so the codes will will reset? Any help will be appreciated.
Old Oct 6, 2008 | 08:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Reseting Codes
Disconnect the battery is about the only way to do it that I know of. Theres also a connector on one of the battery cables that, I think, is the power to the ECM. I remember my L69 having something like that, anyway.
Old Oct 7, 2008 | 12:29 AM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Reseting Codes
Yeah, check the positive battery cable for a couple of connectors. On my 89, they look like o2 sensor connectors. Disconnect them for a couple minutes and that will clear the codes. Those connectors are the main power for the ecm, or atleast one of them is. I just disconnect them both to clear my codes when I need to.
Falcon50
Aug 22, 2020 03:26 PM
Ed1LE
Sep 30, 2018 09:14 AM
okfoz
Oct 13, 2015 02:19 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
