couple 3 questions
Old Oct 6, 2008 | 10:58 PM
adamsbomb's Avatar
couple 3 questions
In the last month I got two third gens. One is just gonna be a friday night drag car which these questions are in regard to.
1. I am putting in a 350/700r4 combo, the engine is a 90 5.7, would like to up the compression ratio a bit, would I be better using a thinner gasket or pick up some 305 heads?
2. Does somebody know the length of the 700's out of the camaro's? I understand there are long tailshaft and short, not sure which I have in my shop and wondering if it is correct or not. (I could just check my other z but it is at the shop right now).
3. It appears I have forgotten my other question for now lol, (it is hell getting old).
Old Oct 6, 2008 | 11:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: couple 3 questions
It depends which 350 and 305 heads you have.
There's really only one applicable length for 700R4's. As long as it didn't come from a 4x4 or a Corvette it'll work, with the right tailshaft housing put on it.
Old Oct 6, 2008 | 11:26 PM
adamsbomb's Avatar
Dont have the casting numbers off the 350's yet (but they are stock truck heads), but the 305's have 194 valves and I believe 64cc chambers.
The tranny is out of a truck also, but not a 4x4. So it should slip right in?
Old Oct 6, 2008 | 11:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes, if it's a V8 belhousing and you put the F-body tailshaft housing on it.
Old Oct 6, 2008 | 11:38 PM
adamsbomb's Avatar
ahh, I dont have the tailhousing, guess its time to start looking, or maybe just pick up a pg or th350.
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
