will this build up work?
Old Oct 9, 2008 | 12:36 AM
blackdemon89ta's Avatar
I picked up an early 4 bolt main 350 from a 70's truck. I checked the numbers on the block and heads. the heads are 75cc with 1.9/1.5 or 2.0/1.6 valves. The engine suppose to push 270hp. i plan on puttin my tpi system and 416 heads on with a cam from summit. SO will this raise my HP? or NOT? or just keep it stock with just bolt on mods? I'm just looking for something around the 300hp range.
Old Oct 9, 2008 | 01:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It will work. Many have done it. Port clean-up of the heads and 1.94" intake valves would help.
300 HP out of a TPI isn't an easy task. But, the cam is critical. What were you planning?
Old Oct 9, 2008 | 04:24 PM
10secondhopeful's Avatar
Car: '84 Z28
Re: will this build up work?
I don't see why that wouldn't put you at 300HP if not more, like five7kid said, the cam lift and duration specs are extremely important
Old Oct 10, 2008 | 05:19 AM
the cam i was thinking around a zz4 cam specs. nothing too radical just something fun and of course with new springs,lifters and 1.6 roller rockers.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
