Stall after start?
Old Oct 10, 2008 | 03:58 PM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
Stall after start?
My car has started first time EVERY time as my daily driver for the 18 months I have had it.
This past week though sometimes it will fire up as normal, but when the initial RPM spike comes back down it just stalls. Second start works fine.
Any suggestions of where to start problem solving would be GREATLY appreicated
PS - So far seems to be only when re-starting a HOT engine.
Thanks in advance
Old Oct 11, 2008 | 06:45 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Re: Stall after start?
Thanks in advance
I haven't been on this board since maybe a year ago.....and I haven't owned a 3rd gen since I was 18 (I'm 24 now!), but I'll throw a few ideas out there.
Check the TBI injectors for leaking that could possibly be slightly flooding the motor after a warm shutdown. Hook up a fuel pressure gauge to the rail if this is an option.....if it's a fuel pressure-related issue, it could tell you a lot.
I'd also check and clean your IAC valve.
Check for small vacuum leaks.
Check base ignition timing.
Check base warm idle speed.
Lots of possibilities and not every motor reacts the same even when the problem is. Check the simple things first and work your way forward. Hope this helps.
jklein337
Sep 19, 2018 06:23 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
Bryan F
Aug 18, 2015 02:28 PM
