high rpm problems after cleaning throttle body
Old Oct 11, 2008 | 10:56 PM
J-money's Avatar
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
I have a 1992 TBI engine, I sprayed some throttle body cleaner on the TB today and after I crank the car up the rpms reved higher than usual and every time I reved it up the rpms would stay high instead of goin back down. (kinda like the throttle was getting stuck) I let the car run for a while and then drove it for a few miles but it still does the same thing but not quiet as bad. and when I put it the car in drive it pulls by itself up to about 15-20 mph. is this normal for a car to do this after cleaning the TB or will it wear off soon or what?
Old Oct 11, 2008 | 11:04 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Re: high rpm problems after cleaning throttle body
Did you knock a vac line loose or something? Sounds like the car is lean now.
Old Oct 11, 2008 | 11:12 PM
J-money's Avatar
well when i first crank it I had the air box off and so all the vacuum hose the runs to the TB was off and so was everything else that connects to the air box. but after I put every thing back in it still done it but not as bad and the car also started much easier. but I am pretty sure that their all connected tho.
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
justin57
Aug 20, 2015 07:05 PM
