Which AFR heads do I need?
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: Which AFR heads do I need?
Cam (276HR10): http://www.compcams.com/Cam_Specs/Ca...?csid=188&sb=2
Rockers (1.6 Comp Pro Magnum): http://store.summitracing.com/partde...6&autoview=sku
Injectors (Ford 30lb): http://fuelinjectorconnection.com/sh...od&productId=5
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
The installed height of those injectors gonna be alright???
I was told that I would need 32's as well.....
Wanted to try to tune first..... and go from there.
Car: 1988 IROC-Z
Engine: 427 SBC
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks again guys. Just waiting on a water neck to come.
Car: 1988 IROC-Z
Engine: 427 SBC
First start:
http://www.youtube.com/watch?v=wVk-C8jOEmQ
Warm idle:
http://www.youtube.com/watch?v=7BAocE35AhI
Drive away:
http://www.youtube.com/watch?v=EvSuL_VHwvw
For the stock tune, it runs WAY better than I thought. Obviously it runs too rich with the 30lb injectors. Idles good in park @750 rpm. But the idle speed in drive/reverse is too low. The car almost wants to stall. For a stock stall, and 2.77 gears, it is not slugish off the line. I was VERY surprised. Plenty of torque too and I'm running open headers.
Warm idle:
Drive away:
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Abit more lopey than I thought but will be a strong running car thats for sure! MAF cars can take some mods and still work somewhat ok on stock tune. Glad to see its running tho. Congrats. Very nice combination there in a very nice car.
Car: 1988 IROC-Z
Engine: 427 SBC
And a big thank you to everyone else in this thread too that helped me! (Air_Adam, GTA Sammy, 1989GTATransAm)
Orr, I see you put your AFPR in the same way I did. How the heck did you get to that screw to adjust it. Looks like it's going to be a challenge for me!
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
