mystery oil leak
Car: 83 z28
Engine: 350 ZZZ
mystery oil leak
My starter is covered in oil (making it hard to start sometimes) and oil is dripping off the pass side of my oil pan. I checked the valve cover gaskets and oil sending unit and they look fine. The intake manifold is dry too. Does anyone have any ideas.
Abraham
Abraham
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: mystery oil leak
Have you got a bolt in the hole in the front of the block where the smog pump used to mount?
Car: 83 z28
Engine: 350 ZZZ
Engine: 383 Carb
Transmission: 4L60
Put a bolt with thread sealer into the lower hole. Make sure it's short so it doesn't interfere with the fuel pump drive.
Car: check
Engine: check
Transmission: check
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
