Need help with combination??????(406)
Old Oct 12, 2008 | 05:33 PM
406iroc's Avatar
Car: 87 IROC - Z
Engine: 406 smblk
Transmission: 4 speed manual
i ran a track time of 9.1 in the 1/8 with my 3.27 geared t56 iroc and was very upset. Just wanting some help with my new combination and what u think my power and difference in track times would be??? should i change cam or just 1.6 rollers
OLD 406,flattops,stock heads 993,luntai bracket master 230* .480 lift cam,1 5/8 heddman lt , true duals , rpm intake 750vs carb
NEW: dart pro 1 72cc 200cc runners, holley 750 dp, 1.6 roller rockers, victor jr?????
what kind of difference will this make in power???? what about at the track?????? THANKS
Old Oct 12, 2008 | 07:53 PM
406iroc's Avatar
Car: 87 IROC - Z
Engine: 406 smblk
Re: Need help with combination??????(406)
nobody??????
Old Oct 12, 2008 | 08:37 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
I'd be more concerned about the mph and 60 foot time. If that time is truely all your car can do, the mph I'd guess to be 75-77. I'm guessing your 60' time was something like 2.4 when it should be under 2.0 if not under 1.8.
Old Oct 12, 2008 | 08:41 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
keep the rpm intake its a good intake. Shave those 72cc heads down to raise the compression. Get some sticky tires. I think the heads/rockers/carb will make a big difference. Should get you in the 7s. I would put 4.10s in too
Old Oct 12, 2008 | 08:55 PM
406iroc's Avatar
Car: 87 IROC - Z
Engine: 406 smblk
can i maybe run a thin headgasket for comp. to be around 10.3 ? 7's is where i want to be THANKS PS i dont think 9 bolt will hold long with 4.10s hopefully i can swing a moser before long
Old Oct 12, 2008 | 08:59 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
u can't even fit 4.10s in a 9 bolt u can get 3.70s though. I wouldn't get anything till the rear end blows up. My 9 bolts still holding up fine.
Old Oct 12, 2008 | 09:01 PM
406iroc's Avatar
Car: 87 IROC - Z
Engine: 406 smblk
btw my 60ft was 2.1 and 79mph
i dont think i can get in 7s with 3.27 u??? I thought i seen 4.10s on 9bolt .com
Old Oct 12, 2008 | 09:26 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
That combination just sounds like it doesn't work together. I'd guess it needs a tune and better gear for the most part. I'd expect that motor to be capable of a low 8, and mid-upper 7's with the stuff you're looking to do. Granted I don't know all that much about the internals of your motor, but I'm thinking those heads should be okay. My guess is that you're looking at low 10's:1 compression.
Old Oct 13, 2008 | 09:12 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
the problem is his motor needs more compression for that cam. You want to shoot for 10:1. Also .480 lift is pretty puny, the 1.6rockers will raise it up to about ~.500. That and those heads flow great, the double pumper is gonna shave off time by itself. What tranny do you have? What tires are you running? He's right about the tune, make sure you got your total timing set and your carb set up right. I'd also work on my shift points/shifting and launching/driving. Take your air cleaner off too and try to shave any unnecesary weight.
I think he is perfectly capable of runnning 7s. I did 8.10 with a mild 355 vacuum secondary carb and 3.27 gears with 700r4 tranny (junk for drag racing). I could get into the 7s probably just driving it some more but a double pumper would get me there for sure.
InfernalVortex
Apr 20, 2021 11:31 AM
darwinprice
17
Oct 11, 2015 11:51 PM
C409
Sep 23, 2015 04:30 PM
mddaniel
Sep 8, 2015 05:16 PM
trevor1010
Aug 24, 2015 11:29 AM
