AFR on a 383
Old Oct 13, 2008 | 12:03 PM
10secondhopeful's Avatar
Car: '84 Z28
AFR on a 383
Okay this guy i know said that i wouldn't be able to put AFR 195cc eliminator heads on a bored and stroked 1991 L98. is there truth in this or do i need to slap him?
Old Oct 13, 2008 | 12:24 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Re: AFR on a 383
There should be absolutely no problem in bolting these on your short block. Should be a killer combo!
Old Oct 13, 2008 | 12:30 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Re: AFR on a 383
I have them on my 383. No problems. I used the same block as a L98.
Old Oct 13, 2008 | 12:36 PM
Car: '84 Z28
Re: AFR on a 383
Okay thanks guys! I'll make sure to slap him. Okay, quick question, i have a 'unknown' 350 under the hood right now. there is what looks like a production number on the block pad in front of the cylinder head, it ends in a 1975, could that possibly be the year?
thanks
Old Oct 14, 2008 | 04:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: AFR on a 383
I also have the 195 Eliminators bolted to my 383.
Old Oct 14, 2008 | 11:42 AM
Car: '84 Z28
Re: AFR on a 383
Sweet, what kind of power are you pushing, and what cam?
thanks
Old Oct 14, 2008 | 11:54 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: AFR on a 383
I have 210 AFR on my 383 and thats fine. It runs good.........realllllll good.
Old Oct 14, 2008 | 12:13 PM
Car: '84 Z28
Re: AFR on a 383
Sweet man, what kind of CR are you running, what camshaft
thanks
Old Oct 15, 2008 | 04:04 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: AFR on a 383
I don't have any "official" power numbers yet. Still tuning.
Cam's a custom grind from Comp Cams:
XFI 224/230 .565/.576 112LSA
Old Oct 15, 2008 | 10:32 AM
Car: '84 Z28
Re: AFR on a 383
Wow man, those are some nice lift specs, and with ol a 112 lope seperation, nice, i found some like that but with 110LSA, i don't mind though lol, a choppier idle is okay with me
Old Oct 15, 2008 | 05:32 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: AFR on a 383
I have a nice lope. That's part of what I was going for.
Old Oct 15, 2008 | 06:07 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: AFR on a 383
383 using late model 4 bolt main roller block. AFR eliminators 195cc. HSR intake about 400 wheel hp on motor, hoping for near 550 wheel hp on spray
cams is a 230/245 .603/.613 109lsa custom grind hydraulic roller
383 and AFR 195's work good
LT1Formula
Oct 8, 2015 08:34 PM
ULTM8Z
Oct 2, 2015 01:25 PM
