car smoking,not losing oil
Old Oct 14, 2008 | 02:48 PM
zee28's Avatar
Car: 86 iroc
I have a 86 iroc lg4 with 150000 miles.it started smoking alittle on start up and at long stop lights.I figured this was valve leaking but I have checked my oil level and it hasnt changed.I was told this could be a bad master cylinder sucking brake fluid into vacum lines.I have never heard this before,anyone heard this one.Guess I will start looking at motors.O,it seems this smoking started all of a sudden,not a progressive thing.The car is stored alot and not driven much,maybe 300 m iles in the last 2 years.thanks
Old Oct 14, 2008 | 05:33 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: car smoking,not losing oil
It doesn't take much oil to make a lot of smoke. It sounds like the well known valve seal/guide issue to me.
Old Oct 14, 2008 | 06:59 PM
zee28's Avatar
Car: 86 iroc
yeah thats what i thought
Old Oct 14, 2008 | 07:05 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
valve seal, lol most chevys do it at start up once they get some miles on them, call it pre start up lube LOL
Old Oct 15, 2008 | 06:17 AM
zee28's Avatar
Car: 86 iroc
yeah,I could handle it at startup.guess I got my money out of the ol 305.time to upgrade.Just curios though,has anyone heard of this master cylinder sucking brake fluid in?thats new to me.
Old Oct 15, 2008 | 06:51 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
It's the valve seals, probably the exhaust.
Mine sat around a lot for two years, and upon returning to regular service, started smoking a lot more than before on startup. I just replace the seals last week. The exhausts were totally nonfunctional.
Totally clean on startup and at all times now!
Old Oct 15, 2008 | 10:34 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
My '73 Nova has that problem. About every 4-5K I have to refill the rear brake reservoir.
How's your break fluid level? If you pull the vacuum hose off is there any residue in there?
midge54
Dec 27, 2019 04:14 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
jharrison5
Aug 19, 2015 05:53 PM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
