L98 Camaro
Old Oct 15, 2008 | 12:10 AM
hybr1d's Avatar
Car: 92 Z28
Transmission: 4-speed auto
L98 Camaro
Do any of u guys have any tricks on how to pass the smog in NV?
Thnks in advance
Old Oct 15, 2008 | 10:55 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: L98 Camaro
Without knowing what you are failing on specifically no.
Be sure that the engine is at operating temp when you have it tested. If you can lean out the mixture and retard the timing that helps on carbed engines. Unless you have a prom chip burner you can't do anything about the mixture. Not sure on a fuel injected car if retarding the timing a few degrees will do anything.
Other then that just general maintenance. Spark plugs, cap and rotor, plug wires, O2 sensor, air filter, PCV valve, fuel filter, etc, etc. I wouldn't just go out and replace these things, but inspect and replace as needed.
Old Oct 15, 2008 | 05:34 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: L98 Camaro
Run it down to a couple gallons and put in a couple bottles of "guaranteed to pass". Just alcohol really.
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 19, 2015 10:07 PM
Winchester1094
Aug 18, 2015 10:23 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
matthew911
Aug 12, 2015 09:38 AM
