check engine light
Old Oct 15, 2008 | 07:51 PM
SLS85IROC's Avatar
Car: camaro IROC-Z28
Engine: V8 350 5.0 TPI
check engine light
how easy is it to hange the lights in the check engine light
Old Oct 15, 2008 | 08:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: check engine light
It's pretty trivial. Remove the escutcheon, and you should be able to pull the bulb out of its holder and insert another one. If you can't get it out with your fingers or with a tool, then you can remove the whole cluster and remove the bulb holder from the back.
Are you sure it's burned out? That almost never happens.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
