Engine Service light illuminates only during freeway driving
Old Oct 14, 2008 | 12:15 AM
bboyghost's Avatar
Car: 91 Rally Sport
Engine: 305 TBI
Okay, I am a new owner (4 days) of a 91 Camaro RS 305. Anyway I bought the car and it runs strong, but i've been taking care of the general maintenance of the vehicle, such oil change refilling the coolant etc. Well everything runs great until I get on the freeway. After about 5 minutes the engine service light will come on, as soon as i park and shut her off,the next time I restart her it'll be gone. What would be causing this?
Old Oct 14, 2008 | 12:18 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Engine Service light illuminates only during freeway driving
Pull the codes and see what the computer is complaining about.
Old Oct 14, 2008 | 12:20 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
my bet is on the egr. you need to find out what code you are throwing, i think there is a write up in the tech articals on how to check for codes.
Old Oct 14, 2008 | 12:24 AM
bboyghost's Avatar
Car: 91 Rally Sport
Engine: 305 TBI
yeah, i gotta have my buddy do it at his shop. was just wondering if anyones experienced anything like this.
Also I've spent a couple hours trying to find similar problems and no luck. The guy that owned it before me just replaced the egr valve so it would pass smog, so it has a brand new one
Old Oct 14, 2008 | 12:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can do it yourself in about a minute with a paperclip.
Old Oct 14, 2008 | 12:33 AM
bboyghost's Avatar
Car: 91 Rally Sport
Engine: 305 TBI
how do you do that?!
Old Oct 14, 2008 | 12:51 AM
bboyghost's Avatar
Car: 91 Rally Sport
Engine: 305 TBI
nevermind i think i figured it out. Thanks for the tip
Old Oct 14, 2008 | 12:57 AM
87tpiz28's Avatar
Car: 1987 z28
Engine: 305tpi
Axle/Gears: 2.73 posi
Sounds like the speed sensor... mine would do that only when it would get into 4th gear. In my case it was the speedometer since it was not working, I fixed that and no more SES lights while driving. good luck
Old Oct 14, 2008 | 01:11 AM
bboyghost's Avatar
Car: 91 Rally Sport
Engine: 305 TBI
my speedometer is broken to, sounds like that is the culprit. i'll pull the codes tomorrow just to be sure
Old Oct 15, 2008 | 07:56 PM
87tpiz28's Avatar
Car: 1987 z28
Engine: 305tpi
Thats probly it. My gear had shifted back inside the tranny. Took the lazy way out, removed the drive shaft used an empty caulking tube with 2 slices down the middle to make it fit in the tail housing and used a hammer to move it back in place
Old Oct 15, 2008 | 08:55 PM
bboyghost's Avatar
Car: 91 Rally Sport
Engine: 305 TBI
yeah i pulled the code and it was 24 "malfunction in the speed circuit" or something like that. I hoping its just a snapped cable tho and not the problem you had
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
apie2546
Aug 10, 2015 05:43 PM
Omega
Aug 10, 2015 12:46 PM
