Idle/Stalling Problem
Old Oct 17, 2008 | 06:40 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
My car is having an idling problem where it will idle back and forth between about 2000 rpm down to about 500 rpm and then it will eventually stall. This just started happening after completing my 5 speed swap and after having the intake off. What could it be, an intake leak, timing, the P/N switch?
Old Oct 18, 2008 | 02:35 PM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: Idle/Stalling Problem
A vacuum leak would be more consistent then that. My guess is one of your sensors is not operating correctly. IAC maybe? You might have a leak in one of the components that are activated by vacuum but only at specific times. EGR or something. The EGR should not have vacuum going to it at idle though.
Old Oct 18, 2008 | 03:03 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Well the idling problem went away and now it is stalling right after I start it up. It will always start, but it dies right after it fires up.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
