'90 IROC TPI, a couple problems
Old Oct 18, 2008 | 06:07 PM
Raskolnikov's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98 Supercharged
Basic info: 1990 Chevy Camaro IROC-Z 5.7 TPI
1) The right front wheel makes a terrible squeaking sound when driving, started doing it after I drove the car up a curb on the right side by accident then drove off it. It started out only making a squeak when the tire hit a certain part, so when i drove at about 10mph it would go squeak, squeak, squeak, squeak. Now it just constantly makes a rubbing sound.
2) The car will only use 1/2 of the gas in the tank before acting like it is out of gas. I know this because it's a 15 gallon tank, the fuel gauge will read 1/2, and it will do the old sputter and die trick. I then would fill the tank with about 7 or 8 gallons, which, happens to be roughly 1/2 of 15 gallons.
Thanks for the help!
Old Oct 18, 2008 | 11:14 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: '90 IROC TPI, a couple problems
Unfortunately, i can't hear your "squeak, squeak, squeak, squeak" to properly diagnose your problem, but I'd say your first problem is a wheel bearing. That's the most likely and cheapest thing to fix.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
