engine missing @ high rpm and hard throttle
Old Oct 24, 2008 | 11:54 AM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
hey this problem just started yesterday out of the blue, i started up my88 gta to go to work and there was a car coming pretty fast behind me when i got out of my drive way so i accelerated pretty hard and the engine was missing bad at about 3-4k rpm... i drove it the rest of the way to work it seemed to run fine unless i punched it in which case it would still move good but i definitely noticed the engine missing. also i heard a slight ticking when it was missing sometimes at about 4k or so.
dont know where to start any ideas?
Old Oct 24, 2008 | 08:35 PM
ughmas's Avatar
Re: engine missing @ high rpm and hard throttle
well i just drove it to work again tonight and its even worse missing at low acceleration and once in a while at idle
guess ill look at stuff tommorow
Old Oct 25, 2008 | 10:01 PM
84transam87's Avatar
sounds like a spark issue that has gotten worse. use to have an 86 trans am that did that and it was something like a spark plug that backed out or a bad wire. but id look at loose/bad plugs/loose or worn out wires. possible ecm or coil. could also be fuel related and be a fuel filter getting clogged. hope you get it fixed. good luck
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
maroe624
Apr 16, 2017 08:29 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
