ZZ4 cam
Car: 87 iroc camaro/2000 Z71/S-10 LB9TPI
Axle/Gears: 327
ZZ4 cam
I have a ZZ4 i bought from a friend that i am putting a LPE 219 cam into along with some other mods.I pulled the ZZ4 cam and i want to verify its actually the ZZ4 cam. The numbers etchecd on the cam end are 32698R along with 871 WB23. This is obviously some sort of GM code can anyone help verify. I want to sell it but i don't want to mis represent it he's positive his dad didn't change the cam since it was a brand new crate motor when he installed it. For piece of mind i'd like to know. From what i can find in the book the gmpp part number is 10185071 but thats nowhere on the cam itself. All help always appreciated.
Transmission: 4L80E/4L80E
It that "871" or "071"?
The last three digits of the p/n should be stamped on the end of the cam.
Axle/Gears: 327
Re: ZZ4 cam
oops! its 071 which is the last three in the gmpp catalog. Thanks for the heads up!
