Need help locating EST for 90 IROC
Old Oct 26, 2008 | 08:10 PM
derekiroc's Avatar
Where is the EST for 90 IROC? Anyone have picture?
Old Oct 26, 2008 | 08:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Need help locating EST for 90 IROC
only places i know of are behind the passenger side strut tower, or behind the intake manifold near the distributor, more on the drivers side or so.
Look there and see what you can find
Old Oct 26, 2008 | 08:26 PM
derekiroc's Avatar
I looked both places and can not find it. Does anyone have any picture of what it looks like?
Old Oct 27, 2008 | 12:19 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
It's the flat module that is with your relays on the driver side. It bolts to the bracket and has about 4-6 wires coming out of it. It's flat and the mounting screws are off-set.
Old Oct 27, 2008 | 12:35 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I was under the impression that the speed density TPI had the EST built into the ECM - but, I could be wrong.
Old Oct 27, 2008 | 12:57 AM
birdtojag's Avatar
You could be right. I forgot that year was speed density. Haven't worked with many of sd systems.
Old Oct 27, 2008 | 11:50 AM
derekiroc's Avatar
I think you the EST is in the ECM since I can not locate in normal spots. What are symtoms if ignition module dies?
Old Oct 27, 2008 | 01:59 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
if the module dies it will crank like crazy but you wont hear it try to fire. It sounds real smooth when cranking and cranks a bit faster.
1992Vortec
Aug 31, 2015 08:05 PM
g.l.mos
Aug 22, 2015 12:02 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
