oil leak
Old Oct 27, 2008 | 02:47 PM
da_jester's Avatar
Car: 1992 camaro rs
oil leak
i have a 92 rs camaro with a 305 and its leaking oil i think its either the pan gasket, timing cover gasket, or seal around harmonic balancer. it doesnt leak when its running just when driving so i guess its a pressure leak and its spraying up onto foam of the hood the insulation underneath car is soaked from front bumper to the back of the front tires any ideas i dont wana start throwing all sorts of money into gaskets cause over the winter im gona rebuild motor anyways but this is my dd for now and i need it to make me another month until i get my truck back.
Old Oct 28, 2008 | 12:22 PM
kcb37's Avatar
Re: oil leak
Try running it parked at somwhere around 1500 to 2000 rpm, see if you can tell where it's coming from.
Old Oct 28, 2008 | 07:11 PM
da_jester's Avatar
Car: 1992 camaro rs
Re: oil leak
ok so ive decided to just swap oil pan gasket and the timing cover gasket and seal around the crank/harmonic balancer what all am i looking at to do this ive been told that ive got to take water pump and radiator/fan out to get hamonic balancer and that i have to jack up the motor to get the oil pan out is this true?
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
