Anyone removed stock HEI dist and knock circuit?
Old Oct 28, 2008 | 10:46 PM
derekiroc's Avatar
Stock 90 IROC, LB9, want to remove stock HEI dist and knock circuit. Does anyone have recommendations? Still want to run stock ECM for now.
Old Oct 29, 2008 | 11:46 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Anyone removed stock HEI dist and knock circuit?
You can, but the ECM will set codes. You can disable the knock circuit by unplugging the sensor.
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Aug 22, 2015 08:17 PM
midias
Aug 15, 2015 05:07 PM
3rdgenparts
Aug 8, 2015 07:09 PM
