oil leak
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
oil leak
I can't find out were this oil leak is coming from. It drips from the starter onto the y pipe. Any ideas?
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: oil leak
oil pressure sender might be leaking. The intake could also be doing it.
Car: 1991 Camaro RS
Engine: 406
Transmission: t5
Axle/Gears: 373
Re: oil leak
NOT COMING FROM DISTRIBUTOR, INTAKE OR VALVE COVER. IT HAS TO BE THE OIL PAN. WOULD THE REAR SEAL SLING OIL ON TOP OF STARTER? THE LEAK IS VERY BAD.
Re: oil leak
If you have no oil above the starter on the block, it's probably the pan.
Driving it is more then likely causing the air to carry some of it to the top of the starter.
Best thing to do would be clean it, then drive it around the block, easy, then look at it again.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
