Still Wont turn over
Old Oct 23, 2008 | 07:13 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
ok so i just bought a brand new battery and put it on my car that had a two day old brand new starter. I installed the battery and went to turn it over you could hear the starter catch the flywheel then it just clicks. If you turn the motor over by hand about 1/2 a turn you can hear the selinoid drop and then when you go to start it again it will catch the flywheel then just click. So i took the starter back on the warranty and installed the new one hoping to fix the problem but i got the same result. Next i checked all the starter connections and battery connections and the ground and all are good what can be the problem?
Old Oct 23, 2008 | 07:28 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: Still Wont turn over
Did you check the lash (spacing) between starter and flywheel? If the engagement is too tight, it could cause the starter to just jam up. Use a shim or 2 and see how it works.
Old Oct 23, 2008 | 07:44 PM
Engine: L69 H.O
do i put the shims on between the starter and block or between starter and bolt and can i just use washers as shims
Old Oct 23, 2008 | 08:04 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
between starter and block. you can use washers but its not as solid you can get a pack of shims for 3bux at autozone in the help section that has the door handles and all that.
Old Oct 23, 2008 | 08:13 PM
Engine: L69 H.O
tried the washers didnt make a bit of difference this is really frustrating
Old Oct 23, 2008 | 10:32 PM
birdtojag's Avatar
Then check your positive battery cable. It may have some extra resistance somewhere in it. If tests bad, replace it. That resistance could be a power draw and all 12 volts not be reaching the starter.
Old Oct 24, 2008 | 11:16 PM
Engine: L69 H.O
ok so i bought some shims for the starter i put in the mid thickness shim and notice a tiny bit of a difference it wants to engage a little more it has a more firm grab on the flywheel but then it starts clicking should i move up to the bigger shim or move down to the smaller one also i replaced both battery cables to rule them out.
Old Oct 25, 2008 | 12:04 AM
birdtojag's Avatar
will the starter turn over the engine if you jump the posts with a screwdriver? If so, you have a bad connection somehere. How was it before you started doing all this work? Also, is your ground wire hooked to the block or the body? Should be to the block. Clean your connection areas where you have the negative cable and see how that does.
Old Oct 25, 2008 | 09:00 PM
Engine: L69 H.O
ground wire is on the body before the starter just quit all of the sudden it was working perfectly. it will not turn over by jumping post. what are the other two wires on the starter and where do they go? i appreciate the help i tried all the shims with no difference i really want to get this figured out
Old Oct 25, 2008 | 11:49 PM
birdtojag's Avatar
Move the ground wire to the block. You are most likely not getting a good ground on the engine if it is connected to the body. This happened to me when I first started tinkering on cars 12 years ago.
Old Oct 26, 2008 | 11:46 AM
Engine: L69 H.O
alright i will try moving the ground but it was working fine with the ground where it is also do you happen to know where the other two wires on the starter go besides the positive wire
Old Oct 27, 2008 | 12:08 AM
birdtojag's Avatar
Small wire is from the neutral safety switch. The other wires are main power wires to other things like constant power suppy to fuse block. No problem. The body is not really a good ground for the starter. That's why the main ground wire is to the block and the back of the engine has a ground strap to the body. Some ground cables also have a small wire to go to the body as well. Good luck with this.
Old Oct 28, 2008 | 09:25 PM
Engine: L69 H.O
Ok so i still havent figured this out. I have tried every possible things i can think of. I've bought all different sizes of shims and tried all kinds of washers with no luck but i did find something interesting i have some big washers on between the starter and the block and the starter is far enough away from the flywheel that it free turns. When you hit the key you can hear it turning super slowly like it dosent get any power but i have a brand new battery and all new battery cables with a good ground and have all the wires hooked up right. I would like to get this figured out before i have to take it to a mechanic and get overcharged for something i can do by myself.
Old Oct 28, 2008 | 11:29 PM
Trick414's Avatar
Car: 1991 RS Vert
Engine: LO3, 305, TBI
Just for giggles, try to start it with another vehicle and jump start... or swap in a known/good/charged battery.
I've had a few batteries over the years that although new, were a little weak until they got on the car and charged up.
Old Oct 30, 2008 | 02:51 PM
Engine: L69 H.O
I figured it out the starter wasnt grounded wow i feel dumb for this one
Old Oct 30, 2008 | 06:55 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
wasnt grounded?
Old Oct 30, 2008 | 09:32 PM
Engine: L69 H.O
yeah for some reason there is a little post on the back of the starter motor that if not grounded will not allow the starter to work
Old Oct 31, 2008 | 11:47 AM
Brando5641's Avatar
must have a wierd starter. glad you got it going!
Old Oct 31, 2008 | 11:27 PM
birdtojag's Avatar
Nice! Never thought of that. My starters ground from the mounting bolts to the block. Anyway, good job on that one.
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
greenyone
Sep 8, 2015 08:41 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
