RUNNING LEAN AT LOW RPM
Old Nov 2, 2008 | 12:28 AM
Dean_GTA's Avatar
Car: 1988 TA GTA
Engine: L98 Replaced w/ 350/330HP W/TPI
Transmission: Stock 700r4
Axle/Gears: stock 3:27
Got an 1988 Trans am with a 350 TPI. When the car runs at operating temperature it has a hesitation with you give it gas and sometimes you can hear a pop in the exhaust. I has the car on a scanner and I was told that it is running lean at low rpm and at the higher rpm it evens out. Could it be the mass air? No engine codes!
Any ideas?
Old Nov 2, 2008 | 01:58 AM
kcb37's Avatar
Re: RUNNING LEAN AT LOW RPM
Wouldn't hurt to clean it.
Old Nov 2, 2008 | 12:29 PM
Dean_GTA's Avatar
Car: 1988 TA GTA
How do I clean it? What do I use?
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
perZ
Aug 15, 2015 01:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
