Pre '86 Heads?
Old Nov 4, 2008 | 08:37 AM
89'CamaroRS's Avatar
Car: 1989 Camaro RS
Engine: Carb'd 350ci
Axle/Gears: 3.08 limited slip
Pre '86 Heads?
Will pre 86 heads bolt onto my 89 305?
Old Nov 4, 2008 | 11:29 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Pre '86 Heads?
Yes.
Your intake manifold will not match up.
What '86 heads do you have? Why are you replacing your '89 heads? what intake do you intend to use?
Old Nov 4, 2008 | 01:06 PM
Car: 1989 Camaro RS
Re: Pre '86 Heads?
Originally Posted by Sonix
Yes.
Im planning ahead. Putting on better flowing heads, intake, cam, bigger injecters, and a full exhaust on to get a little more ummph. Any suggestions?
Old Nov 4, 2008 | 08:54 PM
90c350's Avatar
Re: Pre '86 Heads?
I dont know any heads that were made in the 80's that would flow any better than the ones on you stock 89? Unless their aftermarket etc??
Old Nov 4, 2008 | 09:19 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Pre '86 Heads?
There were only two differences on the '86 changeover (one '86, one '87)
1) Valve cover bolt pattern changed from perimiter bolts to center bolt ('87)
2) two center intake bolts angle changed from 90* to intake surface to straight up.
#1 will not matter which intake type you use, and the other only requires a little minor grinding of the bolt holes in the manifold to make it work.
Old Nov 4, 2008 | 11:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
He's got a stock '89 TBI. Terrible heads if you want anything beyond what the factory did with them.
Good '86-earlier heads are 416 and 601 castings. Post-'87 equivalents would be 081's. Go with the 081's, everything will bolt right back onto them.
Old Nov 5, 2008 | 09:03 AM
Car: 1989 Camaro RS
Re: Pre '86 Heads?
Exactly.
Ill take a look. Thanks.
Should I keep the I also?
Old Nov 5, 2008 | 11:46 AM
five7kid's Avatar
Not sure what you mean by that.
Old Nov 5, 2008 | 07:27 PM
Car: 1989 Camaro RS
Re: Pre '86 Heads?
Sorry. My bad. Should I keep the Throttle Body Injection or will it be too much of a hassle to burn chips? My end goal is close to 280-300hp and somewhere 300-400tq.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
