How do I know when I need a chip?
Old Nov 4, 2008 | 11:11 AM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Not sure when or if I need to get a custom chip for my car.
It's an original '89 305 tpi automatic car and still has the original chip.
Now it has headers, 350 injectors, higher fuel pressure, pulleys, a five speed, and 3.42 gears (instead of 2.98s or whatever they were. Also thinking about changing to a stock LT1 cam. Might do some basic intake porting this fall as well.
At what point do I need a chip?
Old Nov 4, 2008 | 12:58 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Re: How do I know when I need a chip?
You needed a chip when you changed the injectors. I am assuming that you are running 22lbs injectors, correct? Your car must be running quite rich with the bigger injectors and higher fuel pressure.
Any cam upgrade is going to require tuning (chip burning). Also an LT1 cam is not much bigger than an L98 cam.
Old Nov 4, 2008 | 02:03 PM
Engine: tpi 305
Yep 22# Bosch IIIs. Seems to be running great, except idle is rough and the rpm often surges at idle. I disconnected the IAC which made it a little better.
I know the stock LT1 cam is about like an L89, but I'm dealing with an automatic 305 cam now, which is something like .380 lift. Thought the LT1 stick would give my 305 a little more legs.
who's a good chip provider.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
