oil pump shaft
Old Nov 5, 2008 | 11:39 AM
310IROCZ's Avatar
oil pump shaft
alright heres the deal. I finished building my new 350 last night. I went to drop in the oil pump shaft and realized it was not going to fit. Heres the deal, I know for a fact that i have been able to change out the pump shaft on other SBC with the motor in the car. are there aftermaket shaft that a skinnier so that i can avoid taking off the pan to put the factory rod back in? any tips or suggestions on this?
Old Nov 5, 2008 | 11:59 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Should only go in with the oil pump. I.E., from the bottom.
Old Nov 5, 2008 | 02:39 PM
Damon's Avatar
Re: oil pump shaft
They only go in from the bottom. The collar is too big to drop in from above.
Now, a stock shaft you CAN do from the top but ONLY if the plastic collar has already been installed on the oil pump input shaft stub already. Otherwise, it won't fit from above either.
Sorry, but I think you're hosed.
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
formula_novice
Aug 18, 2015 08:48 PM
