easiest way to test for spark
Car: 85 camaro z28
Engine: 305 but i got a '70 350 LT1
Axle/Gears: 3.08
i have an 85 carbureted 305 i just swapped out the old intake manifold and i think my timing was off until i did what everyone was telling me to do by the compression stroke crap, i did that but my still wont fire but its cranking(but it cranks very fast). what should i do?????? Moderator
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: easiest way to test for spark
You can stick an inductive timing light on any plug wire. Cranking the engine over should fire the light if the plug is firing.
