Starting an engine
Old Nov 9, 2008 | 10:21 AM
Sivalski's Avatar
Starting an engine
I have a '88 L03 that engine hasn't been started for few years. I was wondering what I should do before attempting to start it up such that I won't cause any damage to it. Like the cylinder, what kind of cleaner I can I put into it so I won't tear up the cylinder, or anything like that.
So far I have:
* Changed engine oil
* Changed Gas
Anything specific you'd recommend doing before starting it up?
Old Nov 9, 2008 | 12:16 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Starting an engine
If the engine hasn't been started in over 3 years you may want to:
Pull the sparkplugs.
Use one of THESE and put about 5 squirts of engine oil in each hole.
Crank the engine for 10 seconds.
Clean up mess.
Put plugs back in and make some smoke.
Old Nov 9, 2008 | 12:21 PM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
you may want to pull the distributor and drop a drive tool down into it on a drill and pump some oil through it for a bit before starting it, if anything pull spark plugs and drop some pbblaster down in the holes or oil to lubricate the rings and help the piston get to moving.
also you may want to turn it over by hand a couple of times on the harmonic balancer to make sure nothing is torn up or locked up.
Clean up mess.
supervisor42 i see that you shop at harborfreight too huh? best tool place ive seen so far.
Old Nov 9, 2008 | 01:50 PM
Sivalski's Avatar
Thanks for the tips and quick replies!
I will give it a try tomorrow.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
