90' Iroc won't start, ECM code "EGR FAILURE"
Old Nov 16, 2008 | 06:25 PM
Raskolnikov's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98 Supercharged
The car is 5.7 Liter Iroc-z. TPI.
I had replaced the fuel pump and filter about 800 miles back and it has been running beautifully until now.
Last night after driving to the grocery store and back, about 15 minutes after I got back, i remembered to get another thing and hopped back in the car.
It started, idled for about 2 seconds then just died. Car is getting fuel, tank is full, tried carb cleaner in throttle body.
ECM code is coming up 32, or EGR failure.
Engine will crank and crank, and sounds of light "putt putt" coming from exhaust while cranking, just like when I'm starting on any other time.... suggesting compression.
Think it may be plugs?
Old Nov 17, 2008 | 10:57 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 90' Iroc won't start, ECM code "EGR FAILURE"
Will it start and run if you give it about half throttle and hold it? If yes, then EGR could be stuck open. If not, then it's time to start the usual troubleshooting routine. Does it have fuel pressure, spark, timing slip, etc.
Old Nov 17, 2008 | 07:05 PM
No, it wont start at any throttle, wont fire or anything.
I tested for spark and what do you know, no spark. I took a cable off of a spark plug and had a screwdriver in the boot of the cable, then 1/4 inch from a metal ground.
Old Nov 22, 2008 | 01:04 PM
replaced ignition coil, distrib. cap, rotor
still won't start, no spark! Anybody?
Old Nov 22, 2008 | 02:41 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Have you tried replacing your spark control module? (ESC)
Old Dec 3, 2008 | 11:17 PM
I replaced the ESC, and today I tried to start again.
It wouldn't start. So i put a little carb cleaner in the intake and after some cranking it started for a second then went back to cranking.
I think the starter is to blame, last time I was at the mechanic he said it was bad anyway. Would the starter be the culprit in the case of starting for one second, then cranking? Battery is full, newly charged. Cranking sounds like the nice whirr, for a couple seconds, then will just click as if its out of juice, and repeat that.
Old Dec 4, 2008 | 03:46 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
What about your battery cables?
Check them for stiffness within 6 inches of the terminals, stiffness indicates corrosion between the copper strands.
Still it would have to be a sever cuurent drain to keep the engine from starting.
I'd correct the current drain problem first.
Old Dec 5, 2008 | 08:19 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
I would check you pickup coil. You may also have an issue with the EGR since you are getting that code. Or possibly a short or something confusing the ECM. Might also check voltage going to the coil.
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
mustangman65_79
Aug 11, 2015 03:17 PM
