Someone run 416 head on 350 with tpi ???
Old Nov 20, 2008 | 07:18 AM
eric_pomerleau@'s Avatar
350 oversize .30 with flap top piton and 416 Head with 1.94 , 1.60 valve
I want to know if someone run with kind of this setup with tpi or not
the engine detonate or is ok ??
Thank you
Eric
Old Nov 20, 2008 | 09:13 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Re: Someone run 416 head on 350 with tpi ???
I ran hand ported and polished 416s on a 30 over 327 with TPI (holley stealth ram to top it off). The engine was detonation prone for sure. Could not run more than 30 deg timing, and I had to ramp it in very gradually (could not get it all in before 3500 or I got a lot of knock counts.) The 416/081 head hanging over a 4" bore is not an ideal setup. It will work if that's what you are planning on doing though. Do not run more than 30-32 max timing WOT and keep an eye on your knock retard. You will need to program for this, don't run a stock chip with 36 WOT or you may runinto trouble.
Old Nov 20, 2008 | 09:40 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
If you port the heads, increase the chamber size. That will avoid detonation, and will increase flow if you port in the right areas (near valves and spark plug)
Old Nov 20, 2008 | 11:38 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
deshroud the valves
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
BBSDesigns
Aug 11, 2015 07:39 PM
