Top Dead Center? (TDC)
Old Nov 22, 2008 | 03:40 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Let's suppose someone didn't use a piston stop or any other means to determine TDC when he built an engine .....let's say that person just "eyeballed it" by setting it as close to number 1 piston at TDC as they could determine and bolted the timing tab up so the balancer read that it was TDC. How many degrees could it theoretically be off either way?? Plus or minus 2.10 or what?
How much movement do you really have in the crank before the piston actually starts to move one way or another? In case you haven't figured it out, that person is me! lol. You see, my engine seems to run on the hot side with my timing set at approx. 14 degrees advanced....and I have a hard time believing it needs more since this isn't a huge duration cam it seems to me....224/236 @ .050 with a 113 LSA....or should I give it as much as it'll take at idle then back off??
EDITL My cooling system seems fine, full of anifreeze, fan runs. I even have a Griffin aluminum rad in it. But it runs at almost 220 degrees and the fan never shuts off....it even boils over a tiny bit when I shut it down....and that's at 45 degrees outside!
Old Nov 22, 2008 | 04:52 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Top Dead Center? (TDC)
Okay, try backing off initial. Stock for most SBC is 0 degrees for ESC, and 6 degrees otherwise.
Old Nov 22, 2008 | 10:19 PM
Confuzed1's Avatar
Car: 83Z28 HO
The only thing that remains stock on the car is the engine block....see sig.
Old Nov 22, 2008 | 11:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you only eyeballed it, you could be a good 10 or 15 degrees off in either direction.
Old Nov 22, 2008 | 11:05 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Why are you sweating 220 ?
Old Nov 23, 2008 | 09:52 AM
Confuzed1's Avatar
Car: 83Z28 HO
Thanks Apeiron, that answers the actual question I was asking. So I could very well only be a few degrees advanced when I indicate 14 degrees before TDC.
Because that's 220 at idle, at an outside temp of 45 degrees F., and the fan seems incapable of cooling it down further - that's why. Just think of a summer day when it's 90 degrees outside....I doubt it'll stay at 220 then. It would most likely overheat.
From what I've been reading, timing set too far advanced or retarded can cause an engine to run hot, and perform sub-par. So it seems I need to play more with the timing. I have a bushing installed in the distributor which will only allow 16 degrees of mechanical advance. When I set the timing to 14 degrees initial (so I get 30 degrees total mechanical) - it's running hot.
I'm being conservative because it's a boosted car, but since I could be 10-15 degrees off on the balancer, maybe I'll advance it to 34-36 degrees or higher to see if it likes it better. I have noticed I can advance the timing to 40-plus degrees at idle, and I don't hear any pinging.....I don't know a whole lot about timing a car properly, but I do know 10-15 degrees retarded/advanced can make a world of difference in how it runs.
Old Nov 24, 2008 | 04:52 PM
Confuzed1's Avatar
Car: 83Z28 HO
I decided I'll just get a piston stop and get my timing tab set up right on TDC and go from there....thanks!
1992 Trans Am
May 10, 2023 07:19 PM
two-if-by-sea
Exterior Parts for Sale
Sep 13, 2015 06:52 PM
db057
Sep 4, 2015 07:57 AM
86IROC112
Aug 17, 2015 07:57 PM
