just got a comp cams magnum with some surface rust
Old Nov 23, 2008 | 02:54 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
ok i just got a comp cams magnum cs 270h-10 part #12-211-1 and the big lobes have some surface rust because the cam was sitting for so long never installed just in the box and i was wondering the best way to remove the rust? i also wanted to know if there is anything about this cam that i should know about before i install it thanks
Old Nov 23, 2008 | 03:24 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: just got a comp cams magnum with some surface rust
clean it up with some oil and steel wool.
Old Nov 24, 2008 | 08:34 AM
PR32439's Avatar
I have used 000 steelwool and LOTS of elbow grease... Like Red posted...oil and steel wool... MAKE sure you clean the cam spotless! fine pieces of steel wool every where...
Good luck. Popeye... elbow grease makes killer forearms!
PR32439
beastin91rs
Oct 9, 2015 07:38 AM
hectre13
Sep 8, 2015 03:38 PM
neekolzun
Aug 24, 2015 04:59 PM
LT1Formula
Aug 20, 2015 09:36 PM
