Pedal a bit stiff?
Old Dec 2, 2008 | 05:54 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Pedal a bit stiff?
When I press on my acceleration pedal its a bit stiff to press down; its not as a "ease" to press as some other cars may feel. I don't know if its normal or some kind of build up?
Also is that octane enhancer any good? I've been seeing it around like +7 to +12 octane to your gas... Help at all?
Old Dec 2, 2008 | 06:15 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Re: Pedal a bit stiff?
When the throttle shaft (Shaft that holds the throttle (butterfly) blades) gets worn and loose, it can hang up, especially when they're opening from a fully closed position.
Does it suddenly spring free coming off the line?
Old Dec 2, 2008 | 08:13 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
I actually like having a really stiff pedal, all my cars/trucks have 'em except my 91 bird
Old Dec 2, 2008 | 08:45 PM
xbox07's Avatar
Car: 86' Z28
Axle/Gears: 2.73 (for now)
mine does bout the same but doesn't really ease up during acceleration
Old Dec 2, 2008 | 09:16 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
you could make the pedal softer by putting in a lighter spring.
Old Dec 2, 2008 | 09:33 PM
MBcamaro1990's Avatar
Car: 1990 Camaro
Engine: 305 TBI
Axle/Gears: G92 3.42
Mine has always done that. I found that a few sprays from a can of throttle body cleaner actualy freed it up temporarily.
Old Dec 2, 2008 | 09:35 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Pedal stiffness is related to throttle spring, I wouldn't worry about it. Of my 2 thirdgens (TBI and V6) both pedals are stiff as hell. I've sat in a buddy's TPI car and his pedal was lighter than my dad's Hyundai.
If your engine is stock, or anything other than a built up top performing street/strip motor, octane booster is useless. Higher octane mean higher resistance to engine detonation. If your not detonating, you don't need it. Even if you are detonating, and your engine is stock, you don't need it and you have a problem.
Old Dec 4, 2008 | 07:30 AM
kit-ss's Avatar
Car: 91 TA
Engine: 355 FR Stealth Ram
Axle/Gears: BW 9 BOLT 3.27
My TA was built by the previous owner and had a sticky throttle cable. The cable was on the outside of the shaft mount, so I put it to the inside and its as smooth as butter.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
gmoutdoorsman
Oct 3, 2015 11:42 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
