No start, possible VATS issue?
Old Dec 4, 2008 | 02:59 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
This morning I came out to go to work and my car wouldn't start. The engine doesn't turn over at all, no click from starter relay or solenoid, absolutely nothing. I tried banging on the starter with a wrench thinking maybe a bad starter, but no luck. I also checked the battery connections, both are fine. The only odd thing I noticed is that the VATS security light doesn't come on at all. It usually comes on for just a second when I turn the key to "on", and then goes back off. Could this be a problem with the VATS system? I'm going to try bypassing with a resistor when I get home, is there anything else I should check?
Edit: video of car starting this summer, you can see what the VATS light normally does, currently it doesn't come on at all:
http://www.youtube.com/watch?v=-hhEysp9HXY
Old Dec 4, 2008 | 04:59 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Re: No start, possible VATS issue?
Just tested resistance on the key, and on the plug coming from the ignition. Key read 7.5K, couldn't get any reading at the plug. I'm thinking that the contacts in the ignition aren't reading the key. Would this cause the security light not to come on at all? I'm about to try bypassing with resistors, hopefully that will get it.
Old Dec 5, 2008 | 03:56 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Well, that turned out to be the problem. Either the key contacts in the ignition are worn out, or the wires are broken somewhere. I bypassed it with a resistor and all is well again.
Old Dec 5, 2008 | 08:56 PM
TPI86TA's Avatar
Car: 88 GTA
Im having the same identical problem. Starter not attempting to do anything so i even swapped mine out with a new one and the car has a new battery and tight connections. I also noticed the only odd thing is my security light doesnt come on when i attempt to start the car like it used to. Im thinking the same problem. I have juice at the starter on the red wires. I never was able to reach the purple wire to test that but im guessing im not getting a signal to the starter from there. How hard was it to bypass?
Old Dec 6, 2008 | 02:28 AM
vargasjc's Avatar
The bypass is really easy and should only take about 10 min to do...and the cost is less than a dollar...check out the bypass on the trhirden website...it does an spet by step set up...only about 5 steps though...good luck
Old Dec 6, 2008 | 03:09 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
its simple, the only issue i had was skiving the wires back far enough on the connector because theyre so small
Old Dec 6, 2008 | 04:01 PM
89' RS/blue's Avatar
Car: 1989 RS Camaro
Yes it could very well be your VATS. I had the same problem one time, it wouldnt do anything, no sound at all, it turns out one of the two wires going to my ignition switch was broken, so the vats wouldnt allow it to start. So i just bypassed it. the vats module is under the plastic cover on drivers side, right next to hood release lever, i just jumpered it and now it starts with any regular ignition key, i dont need the chip in the key. So i would check your ignition switch first, its kind of a task to take apart the steering column, but it is doable, u will need a special tool to compress the spring though. B/c on those ignition switches, the two wires are always pulling back and forth everytime u start it, so its only a matter of time before one wire breaks, i've had mine go out twice b/c of the wires breaking. Well anyways, good luck.
Old Dec 6, 2008 | 08:43 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
When the system is working normally, the security light blinks for a second, when you turn the key to on. If the light doesn't come on at all (like mine was doing), chances are that the key resistance isn't being seen at all by the VATS module. There should also be a code 53 present at this point. Also, the fuel pump will not prime.
There is a 2 wire plug that comes from the column under the dash, it should be pretty easy to spot - that's where you do the bypass.
Old Jan 8, 2009 | 03:16 AM
spicoli's Avatar
Car: '91' Firebird
Engine: 3.1 L v-6
Hey guys I'm having the same issue. I can find only 1 yellow wire. Is it ok to put the resistor in line with that one ,or do I need the other wire.
Old Jan 9, 2009 | 06:50 PM
Chrisry1995's Avatar
Car: 89 Trans-Am
Engine: 5.7 TPI
You need 2 wires. You have the wrong wire. It should be right next to the steering colum and has a plastic connector. Undo the connector and put the resistor in the part that goes toward the front of the car. Make sure to measure your key first to know what value you need.
Old Jan 9, 2009 | 10:44 PM
spicoli's Avatar
Car: '91' Firebird
Engine: 3.1 L v-6
Thanks, for the help. That was the only thing I couldn't figure out.
Old Jan 10, 2009 | 04:01 PM
Car: 89 Trans-Am
Engine: 5.7 TPI
Glad you found it. BTW, I had an intermitant condition that drove me crazy. The VAT light worked correctly, but sometimes the starter wouldn't engage...especially when hot. Found the starter enable relay wire connections were bad. It's located on driverside kick-panel.....where the hood release is. Pull off the panel after removing screws and it's the one with yellow, Dk Grn/Wht and Dk Grn wires. Make sure they are clean. Also, the car will fire-up and run if you turn the key on and apply 12 volts to the purple wire going to the starter solenoid....just in case someone is searching. What I did was find the purple wire on top of the motor right behind the air conditioner compresser. I just made alittle area and removed the insulation. Then I just carry a remote starter switch in my toolbox. Because I always have a problem when I'm dressed to go out or pouring rain or something. This way I don't have to climb under the car to get to that starter wire. Hope this helps someone. This way you can always start her up to get home if the VAT fails.
Old Jan 11, 2009 | 11:20 PM
spicoli's Avatar
Car: '91' Firebird
Engine: 3.1 L v-6
Thanks for that little bit of info. Every bit helps.
Glowsock
Jul 24, 2025 03:15 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 9, 2015 05:27 PM
