Help engine smokes out of oil cap!!!
Car: 1985 Camaro Z28
Engine: 305 5.0L (LB9)
Transmission: 700R-4
Axle/Gears: No idea
I was driving my 85 Z28 305 TPI on the highway and i noticed my temp gauge rising and not going down. i was slowing down and all of a sudden the car dies .i pull over my temp is off the charts and when i tried to start her back up the engine didnt turn or anything. after i got the car home i noticed there was no oil in the dipstick. i was shocked because i had changed the oil 1 week prior. this morning i put some oil and started her back up again. 30 secs after smoke was seeping out of the oil cap and i turned the car off immediately. when i looked in the coolant i seen like a brownish mist.
Head Gasket?
Head Gasket?
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Help engine smokes out of oil cap!!!
very well could be
could have cracked heads
most likely since it is puffing out of the oil cap fill it back to FULL and then see if smoke is coming from the dipstick tube could be blowby and or a cracked/broken piston..
Axle/Gears: No idea
there was smoke coming from the dipstick at one point but it went away
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
this wouldn't explain the coolant, but do you have a properly working PCV system? I think engines can smoke like that without...
EDIT: well, not necessarily out the dipstick
Axle/Gears: No idea
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Doesn't matter if the PCV works or not if you run it without oil until it seizes.
Axle/Gears: No idea
I dont think its seized because after i put oil in it it idled fine
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: No idea
I dont know what might be wrong with my car. when i was going on the highway i was problaby giving it too much gas.Could it be my head gasket?
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
He just needs to fix the severe oil burning problem, a rebuild. Or, like you said, a new engine.
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Time to pull it out and either get it rebuilt, or get a new engine. Even if the oil consumption is fixed, the bearings will probably go too. These things do need oil to survive.
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
