random question
Old Dec 5, 2008 | 09:23 PM
84 maro's Avatar
Car: 84 Camaro Sports Coupe
Engine: Carb'd 5.7L 350 W/ Funct. SS Hood
Axle/Gears: Stock for now
random question
are there any plugs out there that you all have noticed an improvement from or does it really matter which ones you use? I grew up with my dad always using ac delco but didn't know if another would be better
Old Dec 6, 2008 | 01:10 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: random question
Back when I had my 355 I changed out to more types of plugs than I care to remember, never noticed anything other than a lighter wallet in many cases. Always ended up going back to the cheapie delco's. They just work. The cheaper Bosch's get suggested quite a bit as well - they're shorter which is nice for header clearance (IIRC).
Old Dec 6, 2008 | 01:25 AM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Re: random question
Ac ,NGK, Accell all did not cost too much. They work just fine!
Old Dec 6, 2008 | 10:02 AM
84 maro's Avatar
Re: random question
okay thanks, exactly what i was looking for does ac make a shorter plug? or are the bosch's going to perform the same... headers are in the works.
Old Dec 6, 2008 | 12:22 PM
Vader's Avatar
Re: random question
Originally Posted by 84 maro
random question
Random response:
Green.
Actually, if you are anticipating having trouble with header clearance, you can try angle plugs:
But seriously, any good standard plug should be suitable, so long as the electrode position is correct, reach is correct, and heat range is correct. Even the stock plugs can be wrong for a modified engine, so consider the installation. Champion makes good plugs, NGK makes good plugs. Autolite is a commodity brand, made to be sold, not used. These are the same people who offer the Fram line of products, so consider the source.
Old Dec 6, 2008 | 02:35 PM
84 maro's Avatar
Re: random question
thanks
Cornholio7979
Sep 20, 2018 02:31 AM
777Shock777
Oct 29, 2015 04:30 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
fonzie85
Aug 13, 2015 11:50 AM
